Inventor Forum
Detail view sort of
5 REPLIES 5
pells22
96 Views, 5 Replies
Detail view sort of
Okay I want to show a detail of a spline cut in a pulley. However I do not want to show the half circle on the main view or any of the broken lines on the detail.
Any ideas? I tried to make a sketch, project geometry and copy that geometry only to get an error.
5 REPLIES 5
in reply to: pells22
You can turn off the circle in the main view by editing the detail view and unchecking
Definition In Base View.
Not sure about the broken lines though... I don't seem to be able to select them.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"pells22" wrote in message news:f1528c4.-1@WebX.maYIadrTaRb...
an error.
> Thanks
MechMan_
To turn off the detail symbol in the parent view double click on the detail view, go to the Option tab, and turn off "Definition in Base View".
I'm not aware of any way to remove the broken lines in the detail view.
MechMan
If by broken lines, you mean the "jaggy" lines, you can RMB and choose
rectangular fence before creating the Detail View and it won't have them.
-Brian
"MechMan" wrote in message news:f1528c4.1@WebX.maYIadrTaRb...
> MechMan
MechMan_
I was thinking that he didn't want any lines that didn't identify an actual part edge.
MechMan
pells22
Thanks, that definition did the trick.
I also learned about the square box option, did not work for me because I only want to show the spline detail, and the box shape forced me to select other objects.
I can live with the jagged lines.
Thanks again this was a big help.
