Inventor General
tvernonbaker
Message 1 of 5 (908 Views)
Accepted Solution
Detail view question: adding dimensions to features outside of view?
908 Views, 4 Replies
03-13-2013 01:48 PM
I'd like to add a dimension from a feature in a detail view to a feature outside the view, exactly like the dimension circled in red below. I cannot find any information on how to do this, but I suspect it is pretty easy!
Can you help?
*Expert Elite*
Cadmanto
Message 2 of 5 (901 Views)
Re: Detail view question: adding dimensions to features outside of view?
03-13-2013 02:03 PM in reply to: tvernonbaker
If the dimension is in your model try inserting it from your model.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
tvernonbaker
Message 3 of 5 (891 Views)
03-13-2013 02:15 PM in reply to: Cadmanto
Thanks, Scott. That was helpful and almost gave me the results I want. The arrowhead and leader now extends outside the detail view (to where the feature would be, if it was shown). See the results, below.
I'd like to show a shortened leader with a double-arrowhead, like the 1.596 REF dimension, but I can't figure out how to replicate it.
*Expert Elite*
Curtis_Waguespack
Message 4 of 5 (885 Views)
03-13-2013 02:37 PM in reply to: tvernonbaker
Hi tvernonbaker,
It's a bit of chore, but you can find steps to do this at this link, for your situation look toward the bottom at the  Update 3-13-2013 section.
http://inventortrenches.blogspot.com/2011/02/foreshortened-linear-diameter.html
Also, take a moment and go here and give this a vote for a future improvment idea:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Foreshortened-Dimension-for-Linear-dimensions/idi...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
Cadmanto
Message 5 of 5 (850 Views)
03-13-2013 06:48 PM in reply to: tvernonbaker
If you could replicate it through maybe adding a plane or a construction line then dimension it in your model, then insert that dimension.  That would give you those results.
Best Regards,
Scott McFadden
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
