After looking at your data set, I have verified that this is a bug. I have
spoken to development about this and they are looking into the issue.
Unfortunately, I have tried a number of things, changing the object
defaults, layer and linetype and I could not find a way around this. The
bug ID is 703668 section lines not following the Global line Scale setting
Thanks for submitting this issue,
Lisa Darrah
Autodesk Inventor Quality Assurance Engineer
wrote in message news:5334698@discussion.autodesk.com...
Hi Lisa,
Thanks for your reply. I have just installed SP2 and still have the same
problem. An example is attached. When you change the global line scale
(GLS), the scale of the detail and hidden lines change, but not the section
line scale. It appears that the section line scale is locked in at the
original GLS (which in this case was 0.4). Is this a bug, or is there an
easy work-around?
