Inventor Forum
Detail Boundary and Section Line Scale is different
5 REPLIES 5
j_loverich
368 Views, 5 Replies
Inventor 11 - Sp1
Why is the scale of my Detail Boundary line different than my Section Line scale? I have set the global line scale so that hidden and section lines look OK, but the detail boundary line spaces are so close that it prints as a continuous line. I am using the same line weight and line type for both detail and section lines. Thanks.
James
5 REPLIES 5
j_loverich
in reply to: j_loverich
Hello. Anyone? Autodesk?
I have tired to reproduce this in r11 sp2 and could not. I verified that my
global line scale is set to 1 and using the same line weight for both detail
and section lines and my still appear correctly.
Could you apply the SP2 patch and see if you can reproduce your problem
still and if so, can you send me the file - lisaDOTdarrahATautodeskDOTcom
Lisa Darrah
Autodesk Inventor Quality Assurance Engineer
wrote in message news:5329075@discussion.autodesk.com...
j_loverich
Hi Lisa,
Thanks for your reply. I have just installed SP2 and still have the same problem. An example is attached. When you change the global line scale (GLS), the scale of the detail and hidden lines change, but not the section line scale. It appears that the section line scale is locked in at the original GLS (which in this case was 0.4). Is this a bug, or is there an easy work-around?
After looking at your data set, I have verified that this is a bug. I have
spoken to development about this and they are looking into the issue.
Unfortunately, I have tried a number of things, changing the object
defaults, layer and linetype and I could not find a way around this. The
bug ID is 703668 section lines not following the Global line Scale setting
Thanks for submitting this issue,
Lisa Darrah
wrote in message news:5334698@discussion.autodesk.com...
Hi Lisa,
easy work-around?
markben
Hi
I am having this same issue on 2013.
I see a bug ID was created but it looks like it has not been fixed.
Any idea when this might be sorted out?
