Inventor Forum
Desk made of aluminum box.
10 REPLIES 10
Message 1 of 11
Squawk
328 Views, 10 Replies
I was wondering what the best approach is to make a desk consisting of an aluminum box.
The Aluminum has to be bent on all the sides to make a "box" and then the sides have to be welded together.
1.
Sketch the base, extrude it the required size. Make new workplanes on the extruded sides to sketch the sides and extrude those as well.
2.
Sketch the base plate. Make an offset the same size as the thickness of the sides. Extrude the base and sides the required size.
3.
Sketch the base plate. Extrude using the "surface" option. Thicken the surface. Share sketch, solid extrude the base to the desired size.
And then of course after one of these steps above, turn it into a sheet metal.
Greatfull for any help!
10 REPLIES 10
Message 2 of 11
-niels-
in reply to: Squawk
Hmm... i think i would:
1. start with sheetmetal
2. draw contour of desk
3. make contour flange
4. add flanges to close box
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 11
JDMather
in reply to: Squawk
Use whatever technique you know - then attach your file here and someone will show you how it should have been done.
Message 4 of 11
Squawk
in reply to: -niels-
Mm.. yes.. didn't think about that.
I already made a version and will post my .ipt as suggested by JD.
Let's see what the aces have to say about it.. 😉
Message 5 of 11
Squawk
in reply to: JDMather
Hi JD, as suggested, I attached the .ipt as I made it how I knew it..
Message 6 of 11
-niels-
in reply to: Squawk
I'd do it like this. (see attached.)
I might edit the "GapSize" for better welding. (it's currently set to the thickness)
Niels van der Veer
The Netherlands
Message 7 of 11
Squawk
Thank you for your help Niels!
But I can't open your file, I have inventor 2012..
But I followed what you wrote earlier and I think this is about what you meant (see attached file)?
Where do you edit the gap size?
Message 8 of 11
-niels-
in reply to: Squawk
Yup, you did exactly the same as i did.
To edit the gapsize: edit the flange and go to the "corner" tab.
In the section "miter gap" you can set the value you want instead of the parameter.
Niels van der Veer
The Netherlands
Message 9 of 11
Squawk
Thank you Niels, that worked like a charm!
Is there a way in Inventor that I can make a weld between those sides in sketch?
Or should I not that in sketch mode (like chamfer, mirror, etc.)?
Message 10 of 11
-niels-
in reply to: Squawk
I would probably put the part into an assembly and add welds there.
(environments tab > convert to weldment, 2012 might have it in a different spot though.)
Niels van der Veer
The Netherlands
Message 11 of 11
Squawk
Ok, will do that.. Thanks!
