Inventor General
*Jeffrey, Dennis
Message 11 of 13 (32 Views)
Re:
11-01-2002 03:18 AM in reply to: *McConnell, Cory
YUP.... There are reasons why you can't do it.... I'd go with option 3.
Dennis
Cory McConnell wrote:
> Why can't it be coded right into DA? Example: da encounters a checked out
> file - it pops up a warning similar to the one I get when I open a file
> that is checked out by another user.
> The way it is now, There are 3 options:
> 1)don't use DA
> 2)setup parallel projects without semi-isolated. If I do this I might as
> well scrap semi-isolated altogether.
> 3)setup a project to use DA and put on my HD so I am the only one that uses
> it. (this of course means I get to rename, copy and move everybody's files.
> Cory McConnell
> BJ Pipeline Inspection
Dennis Jeffrey
CAD Associates - Fort Wayne
Autodesk ASC
(260-432-9695 x 221
*McConnell, Cory
Message 12 of 13 (32 Views)
Re:
11-01-2002 03:25 AM in reply to: *McConnell, Cory
Allrighty.
Cory McConnell
*Unal, Ahmet
Message 13 of 13 (32 Views)
Re:
11-01-2002 04:11 AM in reply to: *McConnell, Cory
Can you tell me how you can rename the file? This
is something that I was trying to figure out. In DA, I can rename Part number
but not the name of the file. RMB doesn't work in the Name column of the manage
section.
Thanks.
Ahmet Unal
Most
of the time when we start a new project, we create many files with informal
file names,Piston.ipt, Piston.idw,Compression Assembly.iam etc.. Once the
designs are finalized we issue part numbers and drawing numbers and move the
parts to the workgroup search paths using DA, changing their file names to
their "official" names in the process. If DA is not functional in the
semi-isolated environment, how do we handle this workflow? Do we have to
rename them using explorer and manually resolve all the links? Doesn't sound
like much fun.
Josh
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
