I have a sub assembly that's used a few different places. If I tell DA to look in the two folders I know the sub will be found, select assembly & part file types, and leave Include subfolders unselected, DA finds nothing. The Files Found: window is empty, but the script beneath it says, "Found 2 file(s)."
If I search the same everything, and select Include subfolders, my Files Found: window has ten files in it, yet the note below the window still says, "Found 2 file(s)."
I'm curious why DA is doing this. Is it not showing all files?
I'm running 2013.
