Inventor General
Active Member
Message 11 of 15 (434 Views)
Re: Design Assistant - Renaming Files
11-02-2012 11:50 AM in reply to: john.retzlaff
When I change the part name (.ipt) in DA, then open the assembly, it works fine.  DA is able to fix the link between the assembly and the update part name (.ipt)
The issue I am having, is how to...at the same time...have the other referenced files link to the new part name.
Scenario.
I have A.ipt.
This is used in A.iam (assembly file), and A.idw (drawing file)
So...lets say I change the part number from A.ipt to B.ipt  (I dont care about the iProperties Part name, I am talking file name here with the proper extension.)
When I open A.iam (assembly file), the new part B.ipt is referenced.  The changes in DA have worked..but
when I open A.idw (drawing file)...the link is not there and I have to find that referenced part in the "Resolve Link" window.
Hope this helps.
Valued Mentor
japike
Message 12 of 15 (426 Views)
11-02-2012 12:07 PM in reply to: phoebus.biron
In the lower pane of Design Assistant, in the action column, have you tried selecting "Update" for your drawing?
Peace,
Jeff
Inventor 2013
Distinguished Mentor
Message 13 of 15 (425 Views)
11-02-2012 12:08 PM in reply to: phoebus.biron
John Retzlaff
Active Member
Message 14 of 15 (414 Views)
11-02-2012 01:04 PM in reply to: john.retzlaff
Ahh.  Now that I didn't try.  I will try and see if that works.  Thank you.
Active Member
Message 15 of 15 (408 Views)
11-02-2012 01:20 PM in reply to: phoebus.biron
Thank you guys.  That worked.  That is definitely a detailed step that should be added to the Wiki site.  If it was on there, I definitely missed it.  Thanks again.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
