face=Calibri>Hello,
size=3>
face=Calibri>Spur gear has own material table. For gear calculation is important
to have these fields filled in a material database
table:
size=3>
style="MARGIN: 0cm 0cm 0pt 36pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1">
style="mso-fareast-font-family: Calibri; mso-bidi-font-family: Calibri">
style="mso-list: Ignore">1.
style="FONT: 7pt 'Times New Roman'">
All fields for material
values that are listed in the Material Value area in the Calculation tab – see
the enclosed image.
style="mso-list: Ignore">2.
And also following
fields for particular standards:
style="MARGIN: 0cm 0cm 0pt 72pt; TEXT-INDENT: -18pt; mso-list: l0 level2 lfo1">
style="mso-list: Ignore">a.
Re - for Steel
according to CSN/DIN/ISO standards
style="mso-list: Ignore">b.
Rm - for
Cast-iron according to CSN/DIN/ISO standards
style="mso-list: Ignore">c.
VHV – according to
style="mso-list: Ignore">d.
JHV – it is for new
ANSI standard only
size=3>
size=3>
face=Calibri>Let me know if you need more
information
size=3>
face=Calibri>Regards
<tony@ddd-services.com>Has
wrote in message
href="news:6143926@discussion.autodesk.com">news:6143926@discussion.autodesk.com...
anyone ever added a material to the gear material spread sheet in the design
accelerator? Also what is with the material codes? I have no clue what
material is what with the descriptions that were used. To me it seem
completely worthless to use the calculation capabilities in the spur gear
design accelerator when can't use or choose the material that will be used to
manufacture the gear. If the material is not accurate the gear calculations
are useless. Frustrating! Does anyone have any advice besides stop using the
design accelerator?
"Pavel Holecek (Autodesk)" <
href="mailto:pavel.holecek@autodesk.com">pavel.holecek@autodesk.com>
wrote in message
href="news:6147539@discussion.autodesk.com">news:6147539@discussion.autodesk.com...
face=Calibri>Hello,
size=3>
important to have these fields filled in a material database
table:
size=3>
the enclosed image.
And also following
Re - for
Steel according to CSN/DIN/ISO standards
Rm - for
standards
VHV – according to
JHV – it is for new
ANSI standard only
size=3>
size=3>
information
size=3>
Pavel Holecek
Design Accelerator - Autodesk
<Has
href="mailto:tony@ddd-services.com">tony@ddd-services.com> wrote in
message
to manufacture the gear. If the material is not accurate the gear
calculations are useless. Frustrating! Does anyone have any advice besides
stop using the design accelerator?
Good mornig
I can't find an equivalent material for AISI 4140 (42CrMo4) )face hardened
Can anybody tell my which material in the list is the equivalent one??
Best regards
Dustin
