Inventor Forum
Deriving materials and sheet metal styles
3 REPLIES 3
287 Views, 3 Replies
Hello.
Deriving components is a good thing.  Unfortunately, there is no way (at least that I know of) to derive the material fields from the source object.  It's a little more complex when deriving sheet metal objects.  In that situation, you not only cannot derive the material, but you also cannot derive the sheet metal styles; but you can the thickness.
Does anyone have a solution, either something I am missing through the "derivie component" command, or an iLogic rule that would work?
Thanks!
3 REPLIES 3
csaba.stupak
Unfortunately, this is not supported directly. The appearance style is copied/derived only when it is used by an object which is derived. For example if you derive a solid body which uses some styles then the derive command will derive the given styles too.
Generally the derive command is used to drive a model, if you change the source component the derived side is updated. It can be tricky if the target document contains more derived parts - they can overwrite the styles. Do you need to derive only the active style of the part? It would be nice to have some workflow when this is needed.
Csaba
in reply to: csaba.stupak
Good Morning.
Yes, deriving the active style of the part would be a positive direction to this. Would you know how?
Thanks.
Stephen Weicikosky
Designer, Body Department
(570) 669-5203 Ph, (570) 669-5565 Fax
________________________________
This e-mail transmission and any messages or files attached to it are intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged, confidential and exempt from disclosure under applicable law or agreement. If you are not the intended recipient, you are hereby notified that any review, disclosure, dissemination, distribution or copying of this communication or any part of it is strictly prohibited. If you have received this communication in error, please notify the original sender immediately by replying or forwarding this e-mail to the original sender, then delete it in its entirety from your computer.
csaba.stupak
There was a long discussion in the past - it is tricky to derive material styles :-(. The problem is that a document can contain several derived parts. Even more the target document can contain material with the same name. In such case we could either overwrite the material or create a new material e.g. Gold_01. Material has to be consistent within a design environment per customer. Gold, Aluminum etc. materials have to be consistent across parts within the company.
As a workaround I recommend to save the given style to the global library and then use it in the new part. By this you can use the style without deriving it and it is consistent accross parts. Is this workflow acceptable for you, or do you have other workflows where the style derive is required?
Thanks, Csaba
