I have an assembly which is a plated structure
I am using a skeleton file of surfaces to define these plates
I am deriving the required surface/s from this skeleton file into a part file
In the part file I have used thicken to create my plate part. I also turn off the visibility of all derived surfaces in this part
Now in the plate part when I go into edit derived part - the surface I have used is not grayed out showing it has been consumed by my thicken feature???
I place all my part files into an assembly and create views for each part using isolate (I use these views in a drawing which is used for NC plate cutting)
So the problem I am having is that when I place a view in my drawing the derived surfaces are also showing.
I have searched this forum for answers and found a couple of threads. This one http://forums.autodesk.com/t5/Autodesk-Inventor/Bug-Hide-Show-derived-assembly-surfaces-in-DWG/td-p/... that says there is a bug and it’s now been fixed. I am using Inventor 2013 SP1.1 update 2
And this one http://forums.autodesk.com/t5/Autodesk-Inventor/Surfaces-visible-in-IDW/td-p/3612220 also describes the same problem I am having. With the solution being to use the delete face command. I have tried this and it solves my problem.
However I have used this modeling technique for many previous projects on previous versions of inventor and have never had this problem.
As mentioned above I have used isolate to create these views. I have since gone back and created the views by turning off the visibility of all other components and the surfaces do not appear in my drawing views.
Is this a bug in 2013 or has anyone else encountered this problem?
Cheers
Greg
Solved by rhasell. Go to Solution.
I need to make a correction to my comment
"As mentioned above I have used isolate to create these views. I have since gone back and created the views by turning off the visibility of all other components and the surfaces do not appear in my drawing views"
This was only applicable for some views
Hi
You discovered one of my posts, it has subsequently been resolved.
Follow this thread, see if it solves your issue. (Edit: start from message 9 for the resolution)
If not I will be glad to help.
http://forums.autodesk.com/t5/Autodesk-Inventor/surface-visability-in-an-idw/td-p/3669570
