Inventor General
Valued Contributor
Justin_Desilva
Message 1 of 16 (507 Views)
Derived surface not appearing in model
507 Views, 15 Replies
11-08-2012 09:40 AM
Autodesk Inventor LT
I'm trying to derive a surface .ipt file into my model. After selecting the plus include option, the part file is inserted into the feature manager but the object is no where to be found. Any ideas anyone?
JDMather
Message 2 of 16 (499 Views)
Re: Derived surface not appearing in model
11-08-2012 10:03 AM in reply to: Justin_Desilva
Import.pngThere should be a yellow plus + symbol next to Solid Bodies and/or Surface Bodies
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
Justin_Desilva
Message 3 of 16 (492 Views)
11-08-2012 10:21 AM in reply to: JDMather
Thanks JD. Typically yes, but in this instance the gray bubble with a slash remains the same. Can you give it a try?
JDMather
Message 4 of 16 (478 Views)
11-08-2012 11:11 AM in reply to: Justin_Desilva
Try this one. (see attached ipt file)
Valued Contributor
Justin_Desilva
Message 5 of 16 (461 Views)
11-08-2012 03:15 PM in reply to: JDMather
Thanks JD. Unfortunately I'm currently running Inventor LT 2012. Can you provide me with a 2012 version?
JDMather
Message 6 of 16 (456 Views)
11-08-2012 03:42 PM in reply to: Justin_Desilva
Try this one.
Valued Contributor
Justin_Desilva
Message 7 of 16 (450 Views)
11-08-2012 04:46 PM in reply to: JDMather
The .stp translated into 1 composite surface and 1 solid body.
When deriving the part, the options dialog appeared as shown below.
The derived part resulted in a single surface, not shown and a single solid body. Perhaps it's best that I rebuild the components in Rhinoceros, stitch the open seems, and create valid closed solid polysurfaces. I was hoping not to have to do this, but I can't think of any other solutions.
JDMather
Message 8 of 16 (423 Views)
11-09-2012 05:12 AM in reply to: Justin_Desilva
Try this revision.
Valued Contributor
Justin_Desilva
Message 9 of 16 (390 Views)
11-14-2012 02:12 PM in reply to: JDMather
Thanks JD. The parts in the file are viewable but I'm confused by the merging of Surface Bodies Solid 2. The Surface body is not a solid, and thus can't be manipulated as such. Last week I decided to rebuild the components from scratch. Now this may sound tedious at first, but in order to import my models into Keyshot for rendering I must export my model as .step. Creating the components from scratch allows me to easily colorize them in Keyshot. For instance, when creating the screw heads (not shown), tin cavities, or pins, I can combine these solids into a single body, and drop a metalic color onto 1 part, and not 30 individual parts. What did I learn from this? I should build components from scratch for 2 reasons. 1. I can create a component with any number of terminals using rectangular pattern and parameters. 2. If rendering using Keyshot, it's much easier and less time consuming to minimize the number of parts imported into the model.
Valued Contributor
Justin_Desilva
Message 10 of 16 (337 Views)
12-10-2012 06:26 AM in reply to: Justin_Desilva
Hi JD,
I'm having some difficulty with a false body appearing in my model. Can I email you a file I'm owrking on?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
