Hi.
I have just upgraded from inv 2009 to 2012 and have an issue.
Usually in inv 2009 my workflow starts with an skeletal model from which I derive sketches to create parts, before I complete the skeletal model I will normally have created a number of parts which I would insert into a main assembly. Each part could have some or all of the sketches from the skeletal model within it.
It seems inv 2012 works slightly different as some parts that were derived from the skeletal model early in the skeletal models design get later sketches from the skeletal model added to them later in the design. This is not such an issue but these parts constantly need there new 'sketches' visibility turning off as the design progresses and is very time consuming.
Is there a way setting this continuously adding sketches to the part off ?
Thanks for any help.
