Inventor Forum
Derive assembly to part and save as step, with ilogic.?
2 REPLIES 2
LSA-skan
2162 Views, 2 Replies
Hi
I have been searching all over this forum, youtube, google, and what not, and i haven't found a solution for my problem.
When we send 3D models to customers, we always derive the assembly to make it 1 solid part, so the customer cannot disassemble it to copy our product, and then save it as a step file.
I want to Derive an assembly to a part and then save it as a *.step file with an ilogic rule.
I worked out the last part, but i cannot find the Derive assembly code anywhere.
Im not an experienced programmer, i can only Copy paste, so if the solution is already posted in a simular rule, i will not be able to pick what i need from the code 🙂
hope someone can help me !
/LSA-skan
2 REPLIES 2
Hi LSA-skan,
Here's an example that will derive the assembly to a single solid with seams and then save that as a STP file. This example discards the derived part without saving it.
Attached it the code in a *.txt file in case pasting from this forum directly causes formatting errors.
I hope this helps.
Curtis
'set a reference to the assembly component definintion.
'this assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'define the path and file name
Dim sPathandName as String
sPathandName  = ThisDoc.PathAndFileName(False)
' Create a new part file to derive the selected part into
'note: kPartDocumentObject is the default template
'you could specifiy a path and file name for a custom template
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
'create the derived assembly deffinition
Dim oDerivedAssemblyDef As DerivedAssemblyDefinition
oDerivedAssemblyDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sPathandName & ".iam")
'Set derive style options
oDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyWithSeams
'options:
	'kDeriveAsSingleBodyWithSeams
	'kDeriveAsSingleBodyNoSeams
	'kDeriveAsMultipleBodies
	'kDeriveAsWorkSurface
'Create the derived part
Dim oDerivedAssembly As DerivedAssemblyComponent
oDerivedAssembly = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef)
'- - - - - - - - - - - - - - - - save *.stp  file- - - - - - - - - - - - - - - - - - - - - - - - - - -
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
    ' Set application protocol.
    ' 2 = AP 203 - Configuration Controlled Design
    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 3
    ' Other options...
    'oOptions.Value("Author") = ""
    'oOptions.Value("Authorization") = ""
    'oOptions.Value("Description") = ""
    'oOptions.Value("Organization") = ""
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
    oData.FileName = sPathandName  & ".stp"
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
End If
'- - - - - - - - - - - - end of *.stp  file code - - - - - - - - - - - - - - - - - - - - - - - - -
'close the derived part without saving
oPartDoc.Close(True) 'True set's the skipsave boolean variant
MessageBox.Show("STP file created: " & sPathandName & ".stp", "iLogic")
Hi Curtis
First of all, im very impressed that you came up with this in such short time.!
This works on small assemblies (tested with an assembly with 10 parts), but a larger assembly with 258parts (1015 occurrences) the step file contains 93 solid bodies instead of just 1.?!
Do you have any idea why theres is this difference..?
It takes about 5 min for inventor to derive this assembly, is that somehow cut short by the rule, so it never finishes or something crazy like that?
Secondly: the big assemly have diffrent Position, and Views, that i would like to choose between, before it makes the derived part if that is possible..?
/LSA-Skan
