Inventor Forum
Deleting From Content Center
4 REPLIES 4
Cadmanto
2055 Views, 4 Replies
Once you publish an item to the content center if you want to remove it how is this done?
I am not seeing any method to do this.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
4 REPLIES 4
cwhetten
in reply to: Cadmanto
There is a "Delete Family" option.  Are you accessing it from the Content Center Editor (Manage tab > Content Center panel > Content Center Editor)?
Cadmanto
in reply to: cwhetten
Yes,  That is where I am accessing it.  I have used the delete family in the past, but for some reason
it is not an option now.  I am logged in as an administrator so I am not sure when I RC on the item why this command is not showing up.
Best Regards,
Scott McFadden
cwhetten
Is your library view set to Merged View?  You can only do it if your library view is specifically set to one of your read/write libraries.
Cadmanto
That was exactly it.  Thank you.
Usually something simple.
I had used the delete family command before, but the library view was already set, so this time I never gave it a second thought.
Best Regards,
Scott McFadden
