Inventor General
Active Contributor
Message 1 of 20 (5,982 Views)
Default location for templates in Inventor 2013
5982 Views, 19 Replies
04-21-2012 12:42 PM
I'm having problem changing the default location for templates in Application Options of Inventor 2013. If I set the location to a folder in my server, the template files aren't showing up. It's like there's nothing there. I've never found this problem before. The templates are shared on the network, so it's the same for everybody. Now it's necessary to everyone copy them locally, which is not the best practice in my opinion. Is there a solution to that problem?
Mark_Flayler
Message 2 of 20 (5,972 Views)
Re: Default location for templates in Inventor 2013
04-21-2012 05:00 PM in reply to: rogercamp
Check your settings in your project file.
Project File trumps Application Options.
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
Active Contributor
Message 3 of 20 (5,945 Views)
04-22-2012 01:52 PM in reply to: Mark_Flayler
Hi Mark! Thank you for you reply.
Unfortunately it didn't work.
I set my project file to use a template on a network folder, but when I try to create a new file, the window takes like 4/5 seconds and shows me as seen bellow.
New Member
Message 4 of 20 (5,875 Views)
04-26-2012 06:39 AM in reply to: rogercamp
Has anyone came up with a solution for this? I am having the same trouble.
Employee
Message 5 of 20 (5,826 Views)
04-26-2012 08:19 PM in reply to: garyh
I apologize for the inconvenience this problem is causing you.  We are able to reproduce this problem and it will be forwarded to development.
As a possible workaround, can you map the network server location to a drive letter on your local machine?
For example, using Windows Explorer's Tools->Map network drive... set Q: to \\networkserver\c$.  Then use "Q:\" in the Application Options Default Templates file path.
That workaround enabled me to get the File New dialog to display the templates from a networked location.
Clare Bronder
Active Contributor
danzco
Message 6 of 20 (5,716 Views)
05-04-2012 03:17 PM in reply to: cmbronder
Just wanted to bump this thread; we are having the same problem here.  The mapping a network drive is a bit of a kludge solution that we would rather not have to implement for the long term.
Active Contributor
Message 7 of 20 (5,707 Views)
05-05-2012 05:15 AM in reply to: cmbronder
Thank you Clare for your reply. Unfortunately this solution doesn't work quite right for us as the template folder is not in the root of the drive, so I can't map it. I'd have to change it's location which is not what we want.
I hope Autodesk can make a hotfix for it.
Mark_Flayler
Message 8 of 20 (5,677 Views)
05-07-2012 03:56 PM in reply to: rogercamp
I actually tried mapping from the UNC path today and did not experience this problem.  I wonder if it is something environmental...but then again why would it do it in 2013 and not 2012...hmmm
New Member
Message 9 of 20 (5,657 Views)
05-08-2012 03:00 PM in reply to: rogercamp
I have the same issue!!!
:robotfrustrated:
Setup:
  • Path Used "\\SERVERNAME\Cad_Sys_Resources\Inventor\2013\Templates" (Folders for setup resources have no advantage to being on a mapped drive, in fact I feel that mapped drives are like using relative path and therefor BAD, drive letter designation may change).
  • Server did not have indexing on (if that does anything).
  • I have admins to the location.
  • Local Domain Server
Issue:
  • I can't see, select or use my Inventor Templates.
  • How embarrassing as a CAD Manager!
Resolution:
  • Map the network drive.
  • Once mapped you can use the full network path and it works! Why not when it’s not mapped?
Further Investigation:
  • Review if Templates are still functional when the Network Location is mapped as drive and then drive mapping removed?
Active Contributor
danzco
Message 10 of 20 (5,653 Views)
05-08-2012 03:13 PM in reply to: stewart.carberry
Wow, I would not have thought to try that.  Yes, indeed it does seem to still work after removing the drive mapping.  I have not yet tried restarting my computer though; I'll let you know tomorrow.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
