Our office is currently running Inventor 2012, with SP2 installed (Build 219) and the program still seems unable to fully save and utilize a defualt configuration setting for exporting DXF flat patterns of sheet metal parts. Our laser machine requires AutoCAD 2000 DXF, and while I'm able to save a configuration file (.ini) with this setting, I still have to click on the "Options" button and then click "Finish" or it will save to the standard default AutoCAD 2010 DXF file version and our laser will be unable to read the file.
I've read several discussions on here dating back over a year, and apparently this issue was originally promised to be resolved in the SP1 patch, and as far as I can tell it wasn't even fixed in the SP2 patch. Unless I am doing something incorrectly, which is a possibility.
Does anybody know if this problem was ever resolved in Inventor 2012??? Thank you.
