Hi all,
I have so many questions and know nothing about vba and such. I have spare time for R&D so most of my days are spent reading different threads and browsing on the web for answers. I'm sorry if my questions are stupid since most of you seem experts, but I'm still a beginner.
1) Is it possible to add a pulldown menu in a prompted sketched symbol to select predetermined values instead of typing them ourselves? I would like for the symbol to behaviour to be similar to a cad dynamic block.
2) I'm looking to know if we can add simple rules in prompted entries? What I wish to accomplish is to have a default value that fits our need 80% of the time and for exceptions we can write in a different value when prompted. I know we can edit text after inserting symbols but we are rushed quite often and manual editing can be forgotten.
I wish to learn how to do this stuff step by step, I don't want to be handed already done solutions. But you have to be patient because this is all new to me. Normally I'm a user and know I have to be a doer.
Thanks a lot.
I can kind of get what you want with the symbol but to do so you have to make it a 'Custom Properties - drawing' and combine that with Design Checker. I'm not sure if it's what you want
This would be an awesome addition.
Now, if you use Vault you can create a symbol set to use a custom iproperty and have THAT grab it's value from Vault... and in Vault you can set properties to use list values. Bit of a long way 'round though for what should be a simple task.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks to all.
I had such big expectations for this program but it's not cut out to be!
Frankly I feel a work around will be to complicated for a very basic question. It will be much simpler to type in the info.
There is more information available regarding Design Checker at:
http://labs.autodesk.com/utilities/designchecker
