"CMLucey" <How
href="mailto:cmlucey@dillmanequipment.com">cmlucey@dillmanequipment.com>
wrote in message
href="news:f12d13e.-1@WebX.maYIadrTaRb">news:f12d13e.-1@WebX.maYIadrTaRb...
do you put a decal on a cylinder? Easy steps please..haha! Thanks.
-Chris
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:71F3BB5F2BC73A665D8CEC8F19F71A5C@in.WebX.maYIadrTaRb">news:71F3BB5F2BC73A665D8CEC8F19F......
Make a workplane tangent to cyl (click on
workplane tool, select a plan parallel to the one you want, click on cyl's
surface)
Start a new sketch on the tangent
plane
Insert an image (BMP, DOC, XLS) from
the sketch panel bar
Exit Sketch
Issue Decal command
Pick image, then pick cylinder surface as the
face
Check wrap to face
Hit OK
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
"CMLucey" <How
wrote in message
-Chris
href="news:23A7F38F1BCAE428DDDC62BA13BA270D@in.WebX.maYIadrTaRb">news:23A7F38F1BCAE428DDDC62BA13B......
Forgot to add that you can constraint the decal
in space by using projected geometry, constraints and
dimensions...
Sean Dotson, PE
Check the Inventor
href="news:71F3BB5F2BC73A665D8CEC8F19F71A5C@in.WebX.maYIadrTaRb">news:71F3BB5F2BC73A665D8CEC8F1......
surface)
plane
Exit Sketch
Issue Decal command
face
Check wrap to face
Hit OK
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
"CMLucey" <How
wrote in message
-Chris
