style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"dennym" <Just
href="mailto:dennym@adelphia.net">dennym@adelphia.net> wrote in message
href="news:f17cd15.-1@WebX.maYIadrTaRb">news:f17cd15.-1@WebX.maYIadrTaRb...
thought I would pass this on.
Placing a Datum Target Identifier on a dwg.
When your are in the Datum
Target dialog box under Dimension, you have to type in a number indicating the
diameter of the datum target circle.
Normally you can't put in a diameter
symbol before the
number, but I just found out a way.
Make sure your Num Lock light is on.
While holding down the ALT button
on your keyboard, type in
0216 using the numeric keypad. This will put in
a diameter symbol.
ALT 0216 diameter symbol
ALT 0176 Deg symbol
ALT 0177 Plus / Minus symbol
Another problem is, after placing the Datum Target you can't
dimension
to it. That can be solved by putting a sketch of a circle (phantom line) with
it's diameter and locating dimensions on the dwg view. Then you can placing
the Datum Target Identifier on the the circle.
This is not Pretty but it
works.
If anyone knows a better way, let me know
A wish list to Autodesk:
Allow dimensioning to the symbol
Have a diameter symbol already in the
dialog box
Have a option that sizes the datum circle
diameter
Autodesk... Is this on the list for 2013? New Cad manager at a Manufacturer and this is a problem. Users are having to create manual sketched to then sit a Datum Circle on it so it can represent a correct size. Please reply...
