Inventor Forum
DEFAULT SYMBOL IN EDIT DIMENSION TEXT DIALOG
5 REPLIES 5
sgwilliams
426 Views, 5 Replies
LOOKING FOR A WAY TO MAKE THE DIAMETER SYMBOL THE DEFAULT SYMBOL INSTEAD OF THE DEGREE SYMBOL IN THE SYMBOL DROP DOWN ON THIS DIALOG BOX:
DIMENSION EDIT>TEXT TAB
SEE THE ATTACHED SCREENSHOT
Work Station : Custom built, Liquid Cooled, Asus Pro WS X570-ACE Motherboard; AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor; ASUS TUF Gaming NVIDIA GeForce RTX 3060 V2 OC Edition Video Card; 32 GB CORSAIR Dominator Platinum DDR4-2132 Memory ; Samsung 850 EVO 1TB SSD Drive.
5 REPLIES 5
in reply to: sgwilliams
You are not able to change the default symbol in the Edit Dimension dialog.
However you can create a new dimension style with the diameter symbol as a
prefix.
Lati Mu
Inventor QA
a_sima
Please CHANGE that!!! The need of DIA symbol is greater than DEG symbol. THINK!
Regards
Adrian
t_pcoll
in reply to: a_sima
Hi Adrian,
there is logged withlist item for this requirement (#1087837).
Ladislav
boyebusk
in reply to: t_pcoll
Sound really good.
An additional proposal is to have the dimeter, the degree and the +/- symbol as shortcut buttons just under the button that opens the symbol list. This way it is easy and quick to choose the three most used symbols applied in the text.
Regards
Bo
ampster401
in reply to: boyebusk
screenshot from Inv 2011, looks like your request is already present, at least those three symbols are at the very top of the selections.  May not be exactly what you wanted though I'll admit that.
