Inventor General
*John Bilton
Message 11 of 15 (48 Views)
Re: DAcc Worm Gear Nomenclature
11-11-2004 07:58 AM in reply to: WalkerRA
Thanks for that Gary, I'll be sure to pass you any feedback that I recieve! John Bilton
Employee
miluse.latalova
Message 12 of 15 (48 Views)
11-11-2004 11:53 AM in reply to: WalkerRA
Design Accelerator still provides 2 types of models but all of them are simplified. The first one has simplified the tooth profile and the second one is just a simple shape representation that we call 2D.
Employee
miluse.latalova
Message 13 of 15 (48 Views)
11-11-2004 12:02 PM in reply to: WalkerRA
Thank all of you for your points.
> Also the Worm Gear models (ipt) produced are "weak" to
> the point that they are not really suitable for presentation.
> The first thought that occurs to an engineer viewing the meshed Worm and Worm Gear is that "something looks really wrong.
Are you looking for an exact tooth profile or just visual effect like approximate curve would help?
miluse.latalova@autodesk.com
Distinguished Contributor
WalkerRA
Message 14 of 15 (48 Views)
11-11-2004 09:02 PM in reply to: WalkerRA
A better approximation is what I was referring to. If you take a look at the attached sample, you will see relatively large regions of interference.
I've used single arc approximations for involute gearing and splines for many years. It is amazing how little variation there is between a simple arc and an involute profile. I was thinking that utilizing arcs for generation of the worm gear profile would provide similar results - "a lot of bang for the buck"
-Russ
Employee
miluse.latalova
Message 15 of 15 (48 Views)
11-12-2004 07:20 AM in reply to: WalkerRA
Russ,
I see now what you are talking about.
Thank you,
Mila
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
