I have looked at numersous Database Schema is newer than this version of the software help files.
NONE of them fit the problem.
I have un-installed and re-installed the SAME INVENTOR 11 that created the original files. When trying to open the files (that this particular program created) I get the above error message.
NO other versions, test, samples, views or any other product has been installed, removed, or otherwise started and stopped.
1) So, why doesn't the original program open its own files?
2) How do I access the hundred plus files that this program created?
Solved by JDMather. Go to Solution.
Attach example *.ipt file that Inventor "11" won't open.
The CADWhisperer YouTube Channel
Did you ever find the file?
What does iProperties report?
I can EDIT this Reply but can't edit original - Edit Function not available
How to you attach files here?
I've replied to e-mails with attachments but to no avail
Attached are two files ipt and iam
Not sure why you would be getting this problem, but iProperties would seem to indicate that you have not installed Service Packs or Hot fixes (updates) for that release. Not sure where you would find those for an old release.
Checked - 4-12-14 - and it says my program is UP TO DATE.
LIVE UPDATE MAINTENANCE PATCHES is grayed out.
I checked in Communication Center
What does your Help>About Autodesk Inventor say is your current SP?
This is the first time you mentioned trying to run Inventor 11 on Win 8 OS.
http://forums.autodesk.com/t5/Inventor-General/Inventor-11-and-Windows-8-1/td-p/4955468
