Inventor Forum
Cylindrical Cam Segment - back and forward
2 REPLIES 2
1829 Views, 2 Replies
Hello. I'm using Inventor 2012 and need to design a Cylindrical Cam Segment - it's a back and forward system instead of a continuous movement like a regular cam. I've tried emboss, bend, sweep and design accelerator without sucess.
target - make follower (a cylinder) follow the path - up if cam is turned clockwise and down if turned otherside. i've also read these threads, but no solutions yet.
http://forums.autodesk.com/t5/Autodesk-Inventor/transitional-please-help/m-p/3138614
http://forums.autodesk.com/t5/Autodesk-Inventor/Internal-cylindrical-cam-slot/m-p/3630472#M448840
thank you very much for your help.
fernando
cam height
2 REPLIES 2
JDMather
I haven't looked at your file, but -
I suspect you could simply create a cylindrical cam using the Design Accelerator that goes the entire 360° and then Sculpt to fill the unwanted portion.
in reply to: JDMather
