Inventor Forum
Cutting slots and maintaining orientation
3 REPLIES 3
Breeze104
2227 Views, 3 Replies
I need to cut slots in a circular pattern around a flange ring, but I also need the slots to maintain their orientation so the slots are straight.
What I am atempting is to create a shim that once cut can be slid between 2 flange rings and not have to take the bolts all the way out.
I attached a pic of what I am trying to do.  The slot has to stay in that orientation, yet patterned around the circle.
3 REPLIES 3
Hi Breeze104,
If I understand correctly, you'll want to use the Rectangular Pattern tool, and choose the center offset circle as the Direction1 input, and then choose a start point, and set the orientation to Identical.
Note that you might need to set your construction line circle to a regular linetype  in order to be able to use it for the direction selection.
I hope this helps.
Curtis
mpatchus
in reply to: Breeze104
Create a slot cut out like shown and use a RECTANGULAR pattern along a curve to get this result.
Part file attached as well.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Thanks a bunch...I thought there should be a way to do it.  I keep forgetting to look at the drop down extra command features.
