Inventor General
Message 1 of 5 (409 Views)
Cutout appearance problem IV2013 sp1
409 Views, 4 Replies
01-15-2013 03:50 AM
Hello or "tervehdys" as we say here ...
I cant make cutout appearence work with attached images.
Trying to make simple perforated plate .
As I have understood IV should cut out black colour by attached jpeg.
Just cant figure out why wont work ?
(Earlier versions it use to be simple, defined by the pixel in the corner...)
Markus.M
Helsinki
Message 2 of 5 (375 Views)
Re: Cutout appearance problem IV2013 sp1
01-15-2013 11:55 AM in reply to: markus.lahtinen
No sollution yet ?
Printscreen , hopefully helps.
markus
Message 3 of 5 (370 Views)
01-15-2013 12:02 PM in reply to: markus.lahtinen
Since they made some major changes to the appearances in 2013, I am not quite sure.  But, the old way of doing it required you to end the texture filename with &.  This is how Inventor knows that the color of the pixel should be transparent.  See the attached file for an example.
-cwhetten
Please click "Accept as Solution" if this response answers your question.
Message 4 of 5 (355 Views)
01-15-2013 01:10 PM in reply to: cwhetten
Hey ,thanks Cwhetten for trying but as mentioned  its different in IV2013
Inventor (quoted) wiki help gives a well detailed instruction but I cant find out what I´m doing wrong
"You do not have to use image-editing software capable of creating transparent pixels. Autodesk Inventor uses a bitmap interpretation scheme that assigns transparency to black areas within the image.
The image is used as the Cutout map in the Appearance Browser.
  1. Create the texture map. Use black to indicate where transparency is appropriate.
  2. Save the completed texture with the appropriate image format into the desired library folder."
Markus
Message 5 of 5 (310 Views)
01-18-2013 11:46 AM in reply to: markus.lahtinen
Dearest colleagues.
Am I strugling against windmills when beliveing what IV wiki help instructs to do.
How do You make Your custom appearances ?
it shouldnt be this tricky - I must be missing some siple trick.
Would be happy to receive example partfile & cutout image.
Markus
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
