Inventor General
Active Contributor
lemaycj
Message 1 of 5 (217 Views)
Cut coil out
217 Views, 4 Replies
05-17-2012 04:01 PM
I would like some tips on how to cut the coil feature out of the block.  I have included the file.  I thought the split command would be it but was not able to do anything with it.
*Expert Elite*
Message 2 of 5 (216 Views)
Re: Cut coil out
05-17-2012 04:07 PM in reply to: lemaycj
You are going about it all wrong - you have a single solid.
What about the voids between the strands?
This will give you a bit to think about for your next try.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Expert Elite*
Message 3 of 5 (215 Views)
Re: Cut coil out
05-17-2012 04:13 PM in reply to: JDMather
Give it an honest try before looking at this file to see what changes I made.
Active Contributor
lemaycj
Message 4 of 5 (183 Views)
Re: Cut coil out
05-18-2012 10:42 AM in reply to: JDMather
I figured it out for the shape of the cable and fixed that to coil from one-piece sketch.  When I click on Combine command, it comes up with a message: "Could not combine bodies. The part must have at least 2 solid bodies." But it does: a coil and a block... although when you highlight the coil it looks like it is just surfaces still..
*Expert Elite*
Message 5 of 5 (174 Views)
Re: Cut coil out
05-18-2012 12:28 PM in reply to: lemaycj
Attach the file here.
The Combine isn't needed - the only reason I used it is because you were going about the problem the hard way.
All you really need is a block and then Coil-Cut.  One Extrude feature, one Coil feauture, in that order.
As I said originally - I would do it differently.
But since I did trick you with your original file, what I did was
edit the extruded block and select the New Solid icon.
This made two solid bodies in one part file - your Coil as a solid body and your Extrude as a solid body.
Two solid bodies - that is why Combine-Cut worked.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
