Inventor General
Active Contributor
lemaycj
Message 1 of 5 (242 Views)
Cut coil out
242 Views, 4 Replies
05-17-2012 04:01 PM
I would like some tips on how to cut the coil feature out of the block.  I have included the file.  I thought the split command would be it but was not able to do anything with it.
JDMather
Message 2 of 5 (241 Views)
Re: Cut coil out
05-17-2012 04:07 PM in reply to: lemaycj
You are going about it all wrong - you have a single solid.
What about the voids between the strands?
This will give you a bit to think about for your next try.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
JDMather
Message 3 of 5 (240 Views)
Re: Cut coil out
05-17-2012 04:13 PM in reply to: JDMather
Give it an honest try before looking at this file to see what changes I made.
Active Contributor
lemaycj
Message 4 of 5 (208 Views)
Re: Cut coil out
05-18-2012 10:42 AM in reply to: JDMather
I figured it out for the shape of the cable and fixed that to coil from one-piece sketch.  When I click on Combine command, it comes up with a message: "Could not combine bodies. The part must have at least 2 solid bodies." But it does: a coil and a block... although when you highlight the coil it looks like it is just surfaces still..
JDMather
Message 5 of 5 (199 Views)
Re: Cut coil out
05-18-2012 12:28 PM in reply to: lemaycj
Attach the file here.
The Combine isn't needed - the only reason I used it is because you were going about the problem the hard way.
All you really need is a block and then Coil-Cut.  One Extrude feature, one Coil feauture, in that order.
As I said originally - I would do it differently.
But since I did trick you with your original file, what I did was
edit the extruded block and select the New Solid icon.
This made two solid bodies in one part file - your Coil as a solid body and your Extrude as a solid body.
Two solid bodies - that is why Combine-Cut worked.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
