Inventor General
Distinguished Contributor
Anthony
Message 1 of 5 (739 Views)
Cut angle section out of circular hollow tube
739 Views, 4 Replies
12-05-2012 03:53 AM
I have a small section of hollow tube as an IV part which I need to cut to at one end to produce a tapered effect. Attached is a mark up of what I am trying to achieve with the hollow tube. Does anyone have a solution for this ? Thanks
Inventor 2013 Product Design Suite Ultimate
Windows 7 Professional-64Bit 12GB RAM
Intel Xeon W3550 3.07GHz
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Message 2 of 5 (727 Views)
Re: Cut angle section out of circular hollow tube
12-05-2012 05:05 AM in reply to: Anthony
Attach the ipt file here.
Unless I am missing something - it should be a simple Split, Extrude-Cut or Sculpt.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Anthony
Message 3 of 5 (703 Views)
12-05-2012 07:05 AM in reply to: JDMather
Sorry for the bad wording on my post, what I forgot to add was that I had attempted this using workplanes but found it a lot easier to simply create 2 sketchs with the desired taper angle on the tube end and split the solid. Thank you for the reply.
Message 4 of 5 (698 Views)
12-05-2012 07:19 AM in reply to: Anthony
No workplanes are needed.
Simply a sketch with 2 connected lines to do the Split.
Anthony
Message 5 of 5 (693 Views)
12-05-2012 07:25 AM in reply to: JDMather
Many thanks, yes I found the split method to be the most effecive. :smileyhappy:
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
