Inventor Forum
Cut Top of Sphere
1 REPLY 1
rcmodeler
428 Views, 1 Reply
Cut Top of Sphere
Greetings,
In the attached Inventor 2013 ipt, I am trying to use the extrude / cut command to lop off the top of the sphere and I am not having any success. Any help / advice would be appreciated.
Thanks!
1 REPLY 1
blair
in reply to: rcmodeler
Capture.JPGNot sure what the problem was, just deleted your existing sketch, created a new sketch on the work plane, selected construction line, projected the sphere outside profile, created a horizontal line, then a arc with the start and end at the end points of the H-Line with the mid-point on the construction circle. Finish sketch and use the Extrude-Cut.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
