Inventor Forum
Cut Section: Diferent view style in the same view.
5 REPLIES 5
CCarreiras
308 Views, 5 Replies
Hi!
Some guy ask me if inventor can do that:
 It's possible to do a cut view with the cup part with a different view style  from the other "not Cut" half.
I achieve that, whit the cut view + normal view croped  hover the cut view... but this isn´t a accurate process...
Anyone has a better ideia?
CCarreiras
5 REPLIES 5
Cadmanto
in reply to: CCarreiras
Carlos,
I think what you have looks good.  Is the person asking the question not satisfied with what you came up with?
The only other thing I can think of would be a broken view.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
-niels-
You could try using a fill on the sectioned bit.
Make your base and section shaded,
make a sketch on your section,
project the outer edges of the section that needs to be clear,
Fill with white.
(you may need to draw a closed sketch around the area to be filled.)
Just an idea, hope it's useable.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
CCarreiras
in reply to: Cadmanto
Hi!
Thanks guys.
Cadmanto, the question is; ok, it looks good, but is one view above the other, if you move one view the alignement goes away... it's not a good practice. (we can only have alignement vertical or horizontal so one of the alignement is performed manually...)
BTW, I like the fill option... i have to try that...
CCarreiras
mpatchus
You can create an alignment between the two views so that they appear as one view.
The steps to do it are a little funky, but it can be done.
Create a section view showing the interior of one half of your part.
Create a projected view and crop to show one half of the exterior of the part.
Break the alignment for the exterior view.
Create a vertial alignment between the exterior and the interior section view.
Hope this is clear enough.
I was going to post a screen cap, but for some reason the select image button is not working in my browser.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
CCarreiras
in reply to: mpatchus
Hi mpatchus!
Thanks for the reply, but...
The question is: you can only place one kind of alignement in a view... Horizontal or Vertical, not the both...
CCarreiras
