Inventor General
Distinguished Contributor
DewayneH
Message 1 of 7 (443 Views)
Accepted Solution
Cut Flange to a Slope
443 Views, 6 Replies
02-17-2012 05:55 AM
What I have is a bracket that sits on a pitched roof (ipt attached). The part was set up to reflect the positioning. On the lower side of the pitch, the easiest thing was to scuplt the flanges to the slope. Although the flat pattern results in some edges not being perpendicular to the face (See image). These show on the drawing. I realize you can remove these in the drawing but it would be nice to not worry about it.
What would be a better way of handling this situation?
Inventor 2014 Pro-SP1
*Expert Elite*
JDMather
Message 2 of 7 (411 Views)
Re: Cut Flange to a Slope
02-17-2012 08:34 AM in reply to: DewayneH
Extrude the basic shape.
Fillet (bend radius)
Delete the bottom faces and corner radii
Trim the flanges and rips.
Thicken towards the outside.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
JDMather
Message 3 of 7 (408 Views)
02-17-2012 08:39 AM in reply to: JDMather
steps
Valued Mentor
IgorMir
Message 4 of 7 (368 Views)
02-17-2012 06:51 PM in reply to: DewayneH
Here is an alternative suggestion. Please see the attached.
Best Regards,
Igor.
Web: www.meqc.com.au
Valued Mentor
IgorMir
Message 5 of 7 (365 Views)
02-17-2012 07:57 PM in reply to: DewayneH
I like the second version better...:smileyhappy:
Igor.
DewayneH
Message 6 of 7 (331 Views)
02-20-2012 04:39 AM in reply to: IgorMir
I experimented with this method but was wondering if maybe there was something more that could be done after the flange tool to treat the corners.
This is a very good straight forward solution.
Thanks for the help.
Valued Mentor
IgorMir
Message 7 of 7 (322 Views)
02-20-2012 05:47 AM in reply to: DewayneH
Not in the IV 2010, but in later releases the miter corners can be specified while defining the flanges. Or so I was told. But even in the IV 2010 the model still can be improved. In the attached version the whole part is made entirely in sheet metal module. That, in turn, has reduced the amount of entries in the browser.
Best Regards,
Igor.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
