Inventor Forum
Custom title block placement
3 REPLIES 3
1193 Views, 3 Replies
Creating a custom title block in innventor seems to be straight foward however when I save the new title block it offsets from the sheet, up and to the right. How do I get the title block to line up with the sheet
Bill
3 REPLIES 3
Curtis_Waguespack
Hi brankin,
Depending on your situation, you can likely fix this by going to the Tools tab > Application Options button > Drawing tab. You'll see the option to control the title block insert point there.
Or you might just need to specify your insert point in the sketch:
I hope this helps.
Curtis
mrattray
Do you have a seperate border? I find that having an appropriate border helps with titleblock placement for some odd reason.
Mike (not Matt) Rattray
in reply to: Curtis_Waguespack
Thanks Curtis.....that was the problem
