Inventor General
Member
brankin
Message 1 of 4 (314 Views)
Custom title block placement
314 Views, 3 Replies
09-18-2012 12:07 PM
Creating a custom title block in innventor seems to be straight foward however when I save the new title block it offsets from the sheet, up and to the right. How do I get the title block to line up with the sheet
Bill
Curtis_Waguespack
Message 2 of 4 (302 Views)
Re: Custom title block placement
09-18-2012 03:17 PM in reply to: brankin
Hi brankin,
Depending on your situation, you can likely fix this by going to the Tools tab > Application Options button > Drawing tab. You'll see the option to control the title block insert point there.
Or you might just need to specify your insert point in the sketch:
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
mrattray
Message 3 of 4 (270 Views)
09-19-2012 04:55 AM in reply to: brankin
Do you have a seperate border? I find that having an appropriate border helps with titleblock placement for some odd reason.
Mike (not Matt) Rattray
Member
brankin
Message 4 of 4 (261 Views)
09-19-2012 07:44 AM in reply to: Curtis_Waguespack
Thanks Curtis.....that was the problem
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
