Creating a custom title block in innventor seems to be straight foward however when I save the new title block it offsets from the sheet, up and to the right. How do I get the title block to line up with the sheet
Bill
Solved by brankin. Go to Solution.
Hi brankin,
Depending on your situation, you can likely fix this by going to the Tools tab > Application Options button > Drawing tab. You'll see the option to control the title block insert point there.
Or you might just need to specify your insert point in the sketch:
I hope this helps.
Curtis
Do you have a seperate border? I find that having an appropriate border helps with titleblock placement for some odd reason.
