Been bugging me for ages:
When I place a custom ipart (a simple one in this case) the length in my table changes. Anyone know why, and how to stop this?
See attached - Dia 20, 22 and 45 bar.
Regards.
Hi !
You have a purple column in your table, it's a custom value column, it means the values in that column can be filled with custom values everytime you put it in a assembly, or when you criate a new "children".
What you have to do is remove column's property "Custom Parameter Column" column and so the value is always fixed.
To do that, select de column and RMB and pick "Custom Parameter Column" to deselect it.
Regards.
It is supposed to be a custom parameter column - the length can be set at any number.
This is very trivial, and may well be the way it is supposed to behave. It just seems odd, so I thought I would ask.
Regards.
