So as the title says I am running into trouble every time I open a new assembly using Inventor 2014... I am forced to re-import the style every time I go to create a tube & pipe run in a new assembly. I am trying to find some settings to make it a default style but have been unsuccessful thus far. Anyone know how to make my style remain an option and not force me to re-import each time?
Solved by blair. Go to Solution.
I will be very interested in seeing how this works out for the OP, because I have had this issue before and tried this method in 2012, and it didn't work.
I would like to try this in 2014 and see if this same thing is repeated.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Blair: Thanks for the help finding the location of the template file! That was the one thing that was holding me up. I found directions to do so on a previous version (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385597&linkID=9242018) but it looks like they moved the location of the tube and run templates to the location you suggested.
Scott: I replaced the old default assembly with my new one and then restarted my comp and since then when I create a new assembly the styles I imported are remaining so it looks like whatever issue you previously had has been fixed.
Thanks for all the help.
I did that as well. I had a very similar thread like this one about a year ago, and the answer you gave was what I tried. Except it didn't work for what ever reason. I don't know if it was a permissions thing, even though I was an admin to my system, or what. That is why I want to try this again on my home machine to prove to myself that it does indeed work. I am not saying that you are wrong, it is just hard for me to state this as an answer if I have not had success doing it.
