I am making a new Tube&Pipe Style, but I cannot find the custom hose that I need for it
I made a new, custom hose as follows
1. Manage->Content Center Editor-> Library View: Inventor Parker
2. [Expand] Tube & Pipe->Conduits->Hoses->Parker Hydraulic Hose-No Skive --> right click and copy to Custom Modified Content
3. Library View: Custon Modified Content. I change the name to "EVA Hose" and I shrink some outer diameters in the Family Table. Nothing much.
Then I want to be able to use this hose in a Tube and Pipe Style. So I
1. Create Tube & Pipe Run and name it
2. Pipe Run->Manage->Tube and Pipe Styles->Flexible Hose [Expand]
3. Right click "Hydraulic Hose-No Fittings" -> Copy
4. Right click "Hydraulic Hose-NoFittings_Copy"->Edit
5. In General, I right click "Pipe"->Browse to change the family. I want to be able to select my special hose with smaller outer diameters
My custom hose does not show up in the results. If anyone has a clue to how I can find it, your help would be much appreciated.
Solved by blair. Go to Solution.
Thanks, I finally managed to figure this out a few hours ago. I just rebuilt my styles instead of exporting.
This link I found to be helpful, to anyone else having a similar problem: http://cbennertipstricks.blogspot.com/
I also did this, and I'm not sure if it helped or not: http://forums.autodesk.com/t5/Inventor-General/Making-custom-sized-flexible-hose/m-p/4349022/highlig...
that is, instead of copying the hose to Custom Modified Content straight, I "save as" and checked "independent" so it would not be linked to the original hose part. I proceeded to do everything I could to change its name so it would appear as a separate part in the "browse." Anyway, after all this, it wound up working.
