Inventor General
Message 1 of 7 (479 Views)
Custom Content Center - boolean user parameter
479 Views, 6 Replies
08-27-2012 01:14 PM
I have added a blank column to a custom content center family table that has a boolean data type.  When I try to map this to a boolean user parameter in the family template using the parameter mapping in the family properties, I get a "Data types mismatch".  In the template this parameter was set to false.  Am I doing something wrong, or is there a trick to getting this mapped correctly?
Thanks!
Employee
Message 2 of 7 (469 Views)
Re: Custom Content Center - boolean user parameter
08-27-2012 07:29 PM in reply to: cmines
Could you attach your files here?  It will help to figure out your problem.
Inventor Professional 2014
Jingyi Liu
Quality Assurance Team
Message 3 of 7 (451 Views)
08-28-2012 07:14 AM in reply to: cmines
I hope these are the files you need.  Please let me know if they aren't.  I didn't know where the xls file for the custom family is kept, so I just did a save as.   I also noticed the labels for the columns I added were missing, so I took a screen shot of the table in Inventor - where they show up
Thanks for your help!
Employee
Message 4 of 7 (434 Views)
08-28-2012 10:06 PM in reply to: cmines
Hi Cmines
The reason you missed the label was due to no column caption.
Through the model and  spreadsheet, I almost see your point, there are several boolean type user parameters, you want to map to it.
you can only map a boolean parameter to feature suppression or working feature visibility.
So far, you can only define a numeric type user parameter in your model, and add a integer/real type in family table to map it.
Jingyi Liu
Message 5 of 7 (424 Views)
08-29-2012 06:01 AM in reply to: cmines
Hi Jingyi Liu,
Thanks for checking in to this.  Just to make sure I understand correctly,  if I have 10 members in a family, for example, that when placed as a standard content center part I need user parameter A to be true and all other members in the family should have user parameter A set to false, it can't be done?  If not, is this a feature that will be added in the future?
Chris
Employee
Message 6 of 7 (407 Views)
08-30-2012 08:24 AM in reply to: cmines
Yes, it can't be done so far, you can't map a boolean type parameter in family table to a boolean type user parameter in your content center part.
As a workaround, you can define a numeric type user parameter (unitless) in part, and define a integer/real parameter in family table and assign its value 0 or 1.
I will log it as a wish.
Jingyi Liu
Message 7 of 7 (404 Views)
08-30-2012 08:35 AM in reply to: cmines
Thank you so much for your help and suggestion!  I will give it a try.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
