Inventor Forum
Curving a part on two axes
7 REPLIES 7
Message 1 of 8
nasreen.b
507 Views, 7 Replies
I would like to create a curved surface from a flat part. I have designed the 3d part on the XY plane and would like to have it curved as if placed on a sphere.
I have attached a picture of what I want to achieve. The part is curved in both the X-axis and Y-axis. Unfortunately I cannot attach the part file due to proprietary rights.
At first I used the Bend Part feature and created a bend on both sides on one axis.This was done by sketching a line in the center of the part, which is symmetric in the x-axis and using Bend->Sides. Then I sketched another line which is symmetric in the y-axis and this intersects with the first line used for bending. I have found that I cannot create a second bend using this new line.
Maybe I am going about it the wrong way. Please advise.
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: nasreen.b
Model in the finished form.
Is it really spherical or just close to spherical?
Message 3 of 8
charlesSLJVX
Ever figure this out? I've got a similar issue
Message 4 of 8
Hi
In my opinion, this is a surface modeling task.
The surface of a sphere must be created; then a sketch of the contours of the product; then project this sketch onto the surface of the sphere with a 3D sketch. Finally, there is surface treatment - cutting, thickening, etc.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 5 of 8
JDMather
in reply to: charlesSLJVX
@charlesSLJVX
Yes.  Model in finished form.
Attach your file here if you can’t figure it out.
Message 6 of 8
charlesSLJVX
in reply to: JDMather
Sorry if this is obvious, but could you clarify what you mean by model in finished form?
Message 7 of 8
JDMather
What does the part look like when the manufacture is complete and ready to put into a box and ship to the customer.  That is the finished form. In the original image the finished form would be a simple Revolve (with follow-on features) - no need to Bend.
Attach your attempt here if you can’t figure it out.
If you really want to Bend - then there was a design contest that used this technique that ran a couple of years ago.  I can post link to solution video if desired, but first I would like to verify the true Design Intent.
https://www.youtube.com/watch?v=Nb-yEu0AqyQ
Message 8 of 8
johnsonshiue
Hi! I think Bend Part command is what you are looking for (3D Model -> Modify -> expand the panel -> Bend Part). You need two separate but perpendicular bend lines (both penetrate the body). Then Bend twice.
Many thanks!
Software Test Engineer
