Inventor Forum
Creating geometry on a curved surfaces
24 REPLIES 24
Message 1 of 25
347 Views, 24 Replies
I have a cyclindrical sheet metal part (.1 thick) that has a series (or a pattern) of cutouts that are radial to the CL of the cylinder. The cutouts are made on a flat metal sheet and then folded to the correct OD before butt welding the ends together.
If I create a workplane on the OD, then create a sketch of the cutout geometry and do an extrude cut, the geometry of the part will not be perfect as the WP is flat and does not take into effect the curve of the OD.
Is there a way to make the cutout geometry on a flat pattern and then fold the piece to the correct OD? This would make the part correct and is how the part is manufactured.
Thanks in advanced!
24 REPLIES 24
Message 2 of 25
JDMather
Can you post the file?
Create a sacrificial planar face.
Start a new sketch on the face and Project Flat Pattern.
Create you sketch geometry.
Cut Across Bend.
Cut the sacrificial geometry.
Probably a few other ways as well.
Message 3 of 25
Why not to cut before folding, then (see attachment, IV11)?
M.
Message 4 of 25
I have no idea what you are talking about (sacrificial planar face). See the attached file. Please dumb your answer down more if you can:)
Thanks!
Message 5 of 25
JDMather
Can you zip and attach the ipt?
Message 6 of 25
This is a simple version. The version I ma working on has a more complex cutout.
Thanks in advance!
Message 7 of 25
> complex cutout.
This is the workflow I'd follow.
M.
Message 8 of 25
Thanks Marco but your method is too complex for me to understand.
Message 9 of 25
JDMather
Since you didn't post the actual dimensions I didn't take the time to build in the parameters as a function of the geometry.
The flat patttern takes several minutes to calculate so be patient.
What release of Inventor did you say you were using?
Message 10 of 25
JD,
I use V11 so I cannot open your file. Thanks anyway!
Message 11 of 25
JDMather
>I use V11
Didn't you think that was important?
Message 12 of 25
I worked on a surface instead of a solid, and on a sector instead of
on the whole cylinder.
I cut out the shape of the surface, and thickened the resulting
sector, so that the cut border are radial everywhere.
But I'm thinking that it is not exactly what you needed (sketch the
cut shape in a plane), so I did as in attachment.
I extruded the section, then I cut the shape, and then I bended it to
get a circular sector, to be serialized around the axis.
M.
Message 13 of 25
I don't get what you are saying.
Message 14 of 25
Awesome, I can almost understand it:>)
When you folded the initial extrusion, how did you get it to change to a arc (diameter)? I would think after you folded it, it would be at an angle, not an arc.
Thanks!
Message 15 of 25
Look at the first Feature & Sketch, it's a line that's revolved as a
surface.
Mike
wrote in message news:5817173@discussion.autodesk.com...
an arc.
Thanks!
Message 16 of 25
angle, not an arc.
Are you talking about B-0101671_SC_CAGE_03?
You have just to properly set the fillet radius. Have a look at folds
parameters.
M.
Message 17 of 25
Why can't I fold this part?
I wan't a radius of 1.720.
Thanks!
Message 18 of 25
Because the line in sketch4 is not properly constrained to the border
of the solid.
M.
Message 19 of 25
I now have the line constrained but when I try to apply a circular pattern no worky.
Sorry to bug you about this but I need to learn it as I will be doing many more.
Thanks.
Message 20 of 25
> pattern no worky.
I created a new work axis, that is the axis of the arc. It should
coincide with X axis, but if you use X axis for the circular pattern
it works bad.
You also should pay attention to properly constrain sketches to
improve precision.
Have a look at the attachment.
M.
