Inventor Forum
Creating finish/texture for flexible braided shunt
7 REPLIES 7
Message 1 of 8
1522 Views, 7 Replies
I'm trying to create a flexible braided shunt in Inventor. My approach was to model it as a solid bar in the shape I want to show and then add a texture or finish to make it appear correct. The closest I can find to its apperance in the Autodesk libraries is carbon fiber. I would appreciate any guidance towards a better solution.
7 REPLIES 7
Message 2 of 8
mcgyvr
learn to add textures/color styles.. There are numerous tutorials on youtube..
Message 3 of 8
in reply to: mcgyvr
As I mentioned, I was able to add a carbon fiber appearance to the part but I'd like something better and I can't find anything in the Autodesk libraries. What are my other options?
Message 4 of 8
mcgyvr
as I mentioned, you CAN add "new" colors/materials/textures to the libraries or customize the current ones..
You can even create brand new libraries..
Start your "training" here
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-8EDAC525-826A-41F0-A3B5-D51189B9080E
It would also help to state which version of Inventor you are using as the way materials/colors are handled has changed in the recent years..
Message 5 of 8
in reply to: mcgyvr
Anyone have suggestions on where I can find other libraries or textures?
Also using Inventor 2014
Message 6 of 8
mcgyvr
For texture images..
I find Google images works just fine with a little editing if needed. or just use the picture you took of the ground strap.. It can be edited to work as a perfect texture (rotate/crop,etc..)
Message 7 of 8
mcgyvr
in reply to: mcgyvr
Like this.. attached
 thats your image BTW.. I just rotated/cropped it
Message 8 of 8
in reply to: mcgyvr
Now I just need you to crop it so that the tiles line up. Just kidding...
Thanks for the help
