Inventor Forum
Creating an extruded length of corrugated steel
3 REPLIES 3
Anthony
3663 Views, 3 Replies
I have a question regarding the best way to model a sheet of corrugated steel. I would guess the easiest and quickest method would be to create a profile curve, offset a thickness and extrude this to the desired length. I was wondering how would I go about sketching out an accurate profile curve that could be used to create the form? Many thanks
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
3 REPLIES 3
mcgyvr
in reply to: Anthony
http://forums.autodesk.com/t5/Autodesk-Inventor/MAking-crimp-plate-using-sheet-metal/td-p/3493960
See JD's solution using contour flange.
Anthony
in reply to: mcgyvr
Hi, thanks for the info but I can't see any step by step guides to the process in the link ? Smiley Indifferent
JDMather
I feel like I must be missing something?
Did you open the file?
You should be able to reverse engineer any Inventor part file - simply edit the sketches and features.
I recommend you stop whatever you are doing and at least go through the Help>Learning Tools>Tutorials and Skillbuilders.
Then search classes here http://au.autodesk.com
Then search Google on Rob Cohee Inventor YouTube
Then search www.amazon.com for a book.
You might also sign up for a class.
Start sheet metal part.
Sketch single line profile.
Contoured Flange.
