Inventor Forum
Creating a wire loop between two connector pins
3 REPLIES 3
edwaugh
677 Views, 3 Replies
Hi all,
I'd like to use the Cable and Wiring tools to model some fibre optics. I can see how this could work well, being able to set and check for the minimum bend radius. However, I'd also like to include a loop of greater than minimum bend radius between the two connection points, we tend to do this to reduce strain on the fibres. Does anyone have an elegant solution for inserting the loop?
Thanks very much
Ed
3 REPLIES 3
JDMather
in reply to: edwaugh
Can't you just drag the spline (node)?
Can you attach sample files?
edwaugh
in reply to: JDMather
Hey,
I gave this a go and it does work, would be nice if the splines would automatically limit to the minimum bend radius rather than me manually adjusting them tho.
Thanks very much
Ed
JDMather
I think what you want can be done with the piping (tube) rather than wire/cable.
