Hello Guys,
My name is Robin, I am an engineering student in the Netherlands.
For my first project we had to create a portable wind turbine, so i've designed a turbine (sketch included as an attachement).
I've worked a little bit with inventor in the past but my experience is unfortunately not so great and i stumbled on creating the ' blades' for this turbine, i am wondering if anybody could help me out? I also included my ipt ant iam files.
- additional info-
one blade makes a total curve of 120 degrees
one blade has a width of about 80 mm
the length of the tube is 700mm
the diameter of the turbine is 300 mm
thanks in advance!
Robin
