Inventor General
Message 1 of 8 (442 Views)
Creating a Flange in Inventor 2013 Sheet Metal Help.
442 Views, 7 Replies
12-20-2013 07:02 AM
Hello everyone,
This is my first post in the autodesk forum. I am having some trouble creating a flange from the bottom cut section of the sheet metal in the attached file. The flange should be flushed with the bottom surface but should be vertical. Everytime I try to do it, it gives me an error message "Not a valid sheet metal edge: adjacent face thickness may be different from sheet metal settings". The whole body is made out of 0.25" plate and the width of the cut section is also 0.25" when I inspect it. Can anyone please let me know what is the problem? I really aappreciate any help.
Message 2 of 8 (420 Views)
Re: Creating a Flange in Inventor 2013 Sheet Metal Help.
12-20-2013 07:32 AM in reply to: prajwal
Sketch1 is missing a coincident constraint between the midpoint of the 30in line and the origin.
Missing a vertical and horizontal constraint on the "left" side.
Missing a dimension on the left side (or equal constraints).
Sketch6 missing constraints and extra dimensions.
Extrusion1 will not result in correct sheet metal geometry.
Extrusion3 will not result in correct sheet metal geometry.
(Do not use Extrusions in Sheetmetal if not experienced.)  (if you examine the Flat Pattern in Wireframe - you should see the problems)
Several sketches that I don't understand the purpose of.
Back in a few minutes with improved design.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Distinguished Mentor
Message 3 of 8 (414 Views)
12-20-2013 07:34 AM in reply to: prajwal
Hi!
Pay atteention to the flat pattern... In real life you will not have the "chanfer" in theinicial sheet.
This is due the cut (extrude). The thickness faces, must be always perpendicular to the top face.
You have to cut it in a different way.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Factory Design Suite Ultimate 2014
Autodesk Simulation Mechanical
Autodesk Simulation CFD
Windows 7
Message 4 of 8 (405 Views)
12-20-2013 07:44 AM in reply to: JDMather
Thank you JDMather. What I am really trying to do is to create a flange from the edge of extrusion 3 to the XZ Plane and parallel to the XY plane. I imported the sketches from AutoCad so had to take off the dimentions. The top section is supposed to look like that, of course without the problem that carloscarreiras8703 has pointed out. I will have to figure out that too.
Message 5 of 8 (404 Views)
12-20-2013 07:45 AM in reply to: carloscarreiras8703
Hi!
Like i said, you must have 90º.
Check the part attached.
Regards.
CarlosC
Windows 7
Message 6 of 8 (393 Views)
12-20-2013 08:04 AM in reply to: prajwal
Is something like this what you are after (see attached).
Message 7 of 8 (380 Views)
12-20-2013 08:33 AM in reply to: JDMather
Yes Sir, This is exactly what I was looking to do. Thank You so much.
I was just wondering what is the purpose of the thicken feature that you have used in the model.
Message 8 of 8 (375 Views)
12-20-2013 08:54 AM in reply to: prajwal
I "cheated" a bit by using surface modeling to complete the part.
It would have been too much work for me (I'm lazy) to use the sheet metal tools, but because I know that sheet metal is uniform Thickness, it was pretty easy to create trimmed surfaces and Thicken to get the desired geometry.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
