Inventor General
New Member
Message 1 of 3 (162 Views)
Creating a Custom Iproperty
162 Views, 2 Replies
07-16-2013 01:07 PM
Hello, I've created a custom Iproperty and have put it into the Title block of the Drawing. The trouble I'm having though, is that I would like that iproperty to be a default property when I open a new drawing, that way I don't have to go and make a new custom property every single time I make a new drawing. So is there anyway to save an iproperty as a default property for inventor? If you have any solutions or ideas it would be much appreciated. Thank you.
mcgyvr
Message 2 of 3 (153 Views)
Re: Creating a Custom Iproperty
07-16-2013 01:20 PM in reply to: BP95
You can just open your template and add the custom field there.. Then each time you start a new part using that template the custom field will be there..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2014 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Curtis_Waguespack
Message 3 of 3 (148 Views)
07-16-2013 01:26 PM in reply to: BP95
Hi BP95,
To follow up on what mcgyvr suggests, there is a bit of trick to doing this if your intent is to pull a model iProperty into the drawing title block:
http://forums.autodesk.com/t5/Autodesk-Inventor/ipt-Custom-iProperties-to-idw-Title-Block/m-p/379641...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
