Inventor Forum
Creating Solid part from .step file
4 REPLIES 4
442 Views, 4 Replies
I have recieved a .step file and am trying to convert this into a solid part. I have tried using the stitch feature however this doesn't seem to work, any ideas?
Tom
4 REPLIES 4
JDMather
Yes, here is an idea - zip and attach you STEP file here.
 or
read this http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
(as a start - doesn't cover the newer Repair Environment).
Cadmanto
Or you could go back to where you got the step file from and ask for a different file format.  Preferably Inventor (.ipt) or Solidworks (.sldprt).
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: JDMather
Thanks, I've had a look at the document but haven't made progress so I've attached the compressed step file. Any help would be appreciated.
chad38
I used the sculpt tool to turn it into a solid body. Is that what you were looking for?
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
