Inventor General
Valued Contributor
Stemdriller
Message 1 of 4 (181 Views)
Creating Dimensions on sketch
181 Views, 3 Replies
12-17-2012 08:11 AM
Hi all
One of our senior designers seems to think there is a setting when creating a sketch that will automatically dimension.
So if a straight line is draw and 5 mm length is entered a 5 mm line will immedialtey be created, he seems to think that you can then immedialtey Dimension said line??
I can't find anything, settings wise, but he is a switched on guy so just wondered if there is any truth to his claim?
Gareth
Message 2 of 4 (177 Views)
Re: Creating Dimensions on sketch
12-17-2012 08:36 AM in reply to: Stemdriller
What version of Inventor are you using?
For the past few releases you can enter the dimensions directly as you are creating the sketch.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Distinguished Mentor
Message 3 of 4 (171 Views)
12-17-2012 09:00 AM in reply to: Stemdriller
As JD said.
App options, Sketch, Heads-Up Display, Create Dim's
Valued Contributor
Stemdriller
Message 4 of 4 (135 Views)
12-18-2012 12:16 AM in reply to: rdyson
Thank you to both for your responses.
That is just what we was looking for.
Thanks again
GW
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
