Inventor General
New Member
inventor444
Message 1 of 2 (118 Views)
Create a sketch with line starting points depending on other sketches
118 Views, 1 Replies
10-06-2012 02:09 AM
Hello
I want to draw a line between the two sketches visible on the image below. The line should be in the plane visible. The starting point of the line should be from wherever the top sketch intersects  the plane of the current sketch. The finnish point of the line should be wherever a line of the bottom sketch intersects the current sketch plane.
There is no tooltip appearing that would allow me to quickly "attach" the starting line to the correct position. Is there such an aid, and how do i turn it on?2.jpg1.jpg
*Expert Elite*
JDMather
Message 2 of 2 (111 Views)
Re: Create a sketch with line starting points depending on other sketches
10-06-2012 05:46 AM in reply to: inventor444
Project Geometry.
and
your first two sketches aren't constrained.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
